greggrimm
Jan 08, 2017Follower
Configuration for Nighthawk X6 - powerline 1200 - and AC1200
I have a Nighthawk X6 - the wifi coverage is weak upstairs.
I purchased a powerline 1200 and access point ac1200. My plan is to connect the nighthawk x6 to the ac1200 upstairs using the powerline 1200.
Is this a workable solution?
What configuration of the router and access point would you recommend?
Thanks in advance!
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello greggrimm
This setup should work fine if you have no issues with the power line connection to the upstairs nothing special would need to be done.
DarrenM
