joker2008
Oct 27, 2018Aspirant
Configuration Question on Nighthawk EX8000
Good Afternoon All,
Just purchased a Nighthawk EX8000 extender. The firmware is on the latest revision as I just updated it today as I was configuring it. I have a question about a possible se...
joker2008
Thanks appreciate it.
With that I could still use backhaul on both so no halving right?
Oct 27, 2018Guru - Experienced User
Backhaul from the second floor to the first is over ethernet. Backhaul from the first to the router is WiFi.
If you can run a second cable from the basement to the first floor, then you could set up both extenders in AP mode, and both would use ethernet backhaul.
joker2008 wrote:
would it be the port on the far left or right
Any of them will work.
