ronsway's avatar
ronsway
Follower
Sep 20, 2017
Configuring WN2500RP as second extender after router change.
AT&T (Uverse) changed my router and now I can't get my second extender to work.  I have a EX7000, (that is now working) and a WN2500RP that I can't configure to the new router.  It still shows the older router names. I have tried the online helps and no luck.  It did work in the past as a ext of the first extender.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Make sure you hold the reset button long enough on the extender to factory reset it then you should be able to do the setup again on the new router.
    DarrenM
