OldnSlow's avatar
OldnSlow
Follower
Jul 22, 2023
Connect to second mesh WiFi6 router using existing Nighthawk app
Can anyone help?
I have an existing WiFi6 mesh system set up using the Nighthawk app at my primary location.
Can I use the same app to connect to another WiFi6 mesh at a different location?
If so can I have a step by step guide for the technically challenged?
Any assistance appreciated.
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi OldnSlow , yes, you can setup a new device in a different location using the same Nighthawk app. Just click on the 'hamburger' menu on the top left of the app > 'Setup a new Nighthawk System' > select the type of NETGEAR device that you'll be setting up next.
    Dexter
    NETGEAR Team
