xsalehx's avatar
xsalehx
Follower
Nov 09, 2015
connect two netgare repeaer dose not work!!!
Hello
I use the wifi extender but it dose not retch the place I want. Then I bught other one to extend the earya more but the problem it dose not work when I conect the wifi repater with other wifi repater.
Is there any posable way to do it?
1 Reply
  • It's not recommended to connect one extender to another. Each extender can cause up to a 50% drop in speed, so the second extender may see up to a 75% drop in speed.
    If you can, connect your extenders to the main router using Ethernet or Powerline. The extenders will function as wired APs. This is the preferred method for extending Wi-Fi coverage.
