dopeselecta
Sep 12, 2013Aspirant
Connect WN3500RP "One Port" to router downstream?
I wanted to know if, after connecting to a wireless connection using the WN3500RP, the "One Port" connection could be used to connect to another router's WAN port to create a sub-network? I live in r...
jmizoguchi
Sep 13, 2013Virtuoso
You will probably going to have an issues but if works you can..
I don't think guest SSID will refuse different subnet if it is simple home end routers .
