AEliza81
May 09, 2018Aspirant
Connected but no internet access
Hello, I use a model EX6100v2. I have 2 network names with it, but my TV only recognizes one. And even though it says "connected" there is no internet access. I have tried every single troubleshootin...
DarrenM
May 11, 2018Sr. NETGEAR Moderator
Have you tried to factory reset the extender by holding the reset button for 10+ seconds then try to set up the extender again by connecting it to the router?
DarrenM
- AEliza81May 15, 2018AspirantYes, I did the reset, and every single troubleshooting process I could find. The 2G network is there, but it just has NO internet access and from looking at it, you can't tell anything is wrong. "It" thinks it's working just fine. And now the 5G network is starting to do the same thing. I think I bought a bad product. Will have to replace it but NOT with Netgear. I'm really disappointed in it. Thanks for the reply....
- MoBo48May 26, 2018Initiate
Mine does the same thing. Also, my I-Phoe 7+ connects through it to the internet, but my wife's old Samsung does not. New TV connects, but Dell XPS computer with Windows 7 does not. I guess if Netgear knew the answer they would tell us.
- AEliza81May 26, 2018AspirantPretty pitiful!!! đ Lame product.
