anupambanerji
Feb 13, 2018Aspirant
Connecting AC1200 EX6150-100NAS Range Extender to Ring Video Doorbell
I connected my AC1200 range extender to my FiOS router yesterday and my iPhone and Mac had no trouble connecting to the 2.4GHz and 5GHz bands on the range extender. When I tried to connect my Ring D...
- Feb 15, 2018
Thanks for your reply, Dexter.
After spending 30 minutes with the Ring support team, they fixed the issue by factory resetting the video doorbell and the product re-connected to the extender without issue. It works just fine, and I don't get connection droputs at all.
The trick is to switch over from the router to the range extender by resetting the Ring device, which isn't explicity metnioned in the instructions, and I'm happy to say the Range Extender works without issue.
DexterJB
Feb 14, 2018NETGEAR Moderator
Hi anupambanerji,
1. What is the firmware version of the extender?
2. Checking on the Ring Doorbell specs linked below, it looks like it is a single band device and can only connect to the 2.4GHz.
https://shop.ring.com/products/video-doorbell
3. Please make sure that the credentials (i.e. WiFi password is correct during setup procedure) are correct.
4. Have you tried changing the wireless channel for the 2.4GHz band on your main router?
Dexter
Community Team
