MaeS
Sep 16, 2015Follower
Connecting my WN2500RP extender
My WN2500RP extender sees my network on the "mywifiext.net". However, when I put in my passphrase I get this: "The Extender was not able to connect to your existing network. If you entered the ...
nhann
Nov 16, 2015NETGEAR Employee Retired
Hi stevenmurdoch99,
Can you please confirm which version of WN2500RP you have?
http://support.netgear.com/product/WN2500RP
http://support.netgear.com/product/WN2500RPv2
Power on the WN2500RP
Press and hold the Restore Factory Settings button on the rear panel for 7 seconds. The extender resets, and returns to its factory settings.
Now try using a different ethernet cable from the extender to your computer.
Then follow the instructions for setting up via mywifiext.net or 192.168.1.250 in your browser
Check if your Orcon Genius Router has a new firmware update by visiting their website.
stevenmurdoch99
Nov 20, 2015Aspirant
I've tried resetting the Extender and the Router several times with no luck.
I have the WN2500RP
I have lots of other devices that connect to the Router ok which makes me think there is some issue with the Extender or its settings.
- nhannNov 23, 2015NETGEAR Employee Retired
Hi stevenmurdoch99,
Thank you for clarifying.
Please contact support for further troubleshooting to determine if a RMA is necessary:
