aero63
Apr 03, 2018Aspirant
Connecting to Firestick
I bought the range extender to improve signal to my Firestick. The Firestick is currently connected to my router. I have connected the Extender to the router and plugged in adjacent to the Firestick...
jvasanth1984
Apr 03, 2018Virtuoso
Hi aero63,
Did you tried connecting any other devices to check if you come across the same issue? Hope you are typing the correct password since password is case sensitive. If that is the case, try to set it up again and see if that helps.
- aero63Apr 03, 2018Aspirant
Yes. Have connected Kindle to it with no issues. Have tried several times to connect Firestick using the correctly typed password but it won't connect
- jvasanth1984Apr 03, 2018Virtuoso
Hi aero63,
Check if it connects fine with router to see if its not an issue with firestick. If it works fine with router, check for firmware upgrade on extender if any and modify wireless channel on the router to see if that helps.
