aero63
Apr 03, 2018Aspirant
Connecting to Firestick
I bought the range extender to improve signal to my Firestick. The Firestick is currently connected to my router. I have connected the Extender to the router and plugged in adjacent to the Firestick...
aero63
Yes. Have connected Kindle to it with no issues. Have tried several times to connect Firestick using the correctly typed password but it won't connect
jvasanth1984
Apr 03, 2018Virtuoso
Hi aero63,
Check if it connects fine with router to see if its not an issue with firestick. If it works fine with router, check for firmware upgrade on extender if any and modify wireless channel on the router to see if that helps.
