Rxmichele
Aug 12, 2016Aspirant
Connecting to internet with Ex6120 (AC1200)
I just set up my new range extender (model EX6120 - Dual band extender) however everytime I attempt to connect to it (on either band), it asks for the security key, after it accepts it, it then pause...
Rxmichele
Aug 17, 2016Aspirant
Tried to download the firmware the encountered this:
http://i.imgur.com/V4Q68FV.png
before it unzipped
DarrenM
Aug 18, 2016Sr. NETGEAR Moderator
Hello Rxmichele
You will want to load the .chk file onto the extender to update the firmware. You will want to log into the extender then go to Maintenance then firmware update there you click browse and select that file. Make sure you are connected to your extender via Ethernet when updating to no corrupt your install.
DarrenM
