mcdoug6
Feb 01, 2018Aspirant
CONNECTING TO ROKU
When the ROKU asked for a password - is it the WIFI password or the Router password?
Roku shows that it's receiving a great signal from the extender but it won't connect.
Thanks,
Doug
- DarrenMSr. NETGEAR Moderator
It would be the wifi password that it is looking for.
DarrenM
- mcdoug6Aspirant
What about the extender. My WIFI name might be SR54 and I put in my Wifi password to use ROKU. The extender is SR54EXT - do I use the same password to connect it to the ROKU? It didn't seem like it wanted to accept the WIFI password.
Thanks,
Doug
Yes if you did not change the password of the extender when you set it up typically its the same wifi password as your main router.
DarrenM
