NOThappy999's avatar
NOThappy999
Follower
Apr 06, 2019
Connection issues w Extender EX 3700 and Nighthawk R6900P
I bought 2 EX 3700, with the objective of providing extended distance for my nighthawk as well as wired connectivity.  Neither of my EX 3700 will see the 5G on the Nighthawk.  I tried reconfiguring the Nighthawk so that it manages both as the same 'Smart Connect'.  Still no luck.  So I can continue to over use the 2.4 band.
Second issue, and primary purpose of the purchase was plugging in a Hub into the extender to provide internet to desktop PCs in other room.  The EX 3700 will display on the wired connection, but will not allow internet to pass through.  Do I need to find a different solution?
Update (10 minutes later):  I went had a cup of coffee and was suprized to see the internet passing through on one of my boxes.  So I know it works for that box.  I suspect the other is defective.  Still have the 5G issue of not communicating over it.
1 Reply
  • plemans's avatar
    Disable the smart connect feature on the R6900P. Smart connect can cause issues with wireless extenders as the router itself manages which device connects to which channel. See if this resolves your issues of connecting the extenders. here's some more info on troubleshooting extenders that is helpful.
    https://kb.netgear.com/25731/Troubleshooting-NETGEAR-WiFi-Range-Extenders
    You can setup fastlane with the extenders to optimize speeds/distances depending on what your needs are for that specific extender.
    https://kb.netgear.com/24662/What-is-FastLane-Technology-and-how-do-I-configure-it
