hughbacca
Jul 24, 2014Novice
Connection to network but not internet on one device
Hi, I recently got a WN3000RP. I found the set up easy and was able to connect all my devices (pc, laptop, phone). I set up the extender on my pc as this was the main reason I bought it due to a w...
storm_2003
Jul 28, 2014Novice
If you just want to connect wired on your pc I suggest you disable the wireless card.
Please check if the local adapter is set to dynamic or static.
Is it a valid IP address within the router's range?
Also check if the DNS address.
If DNS not pingable try to set a static DNS on the extender using the router's IP address.
