CW1971
Jan 14, 2017Aspirant
Connection
If I connect my extended to my wifi router by utilizing the WPS buttons on both the extender and router and they connect. Do I need to do anything else? In the instructions step 6 mentions connecting ...
- Jan 15, 2017Got it. Had to go through my laptop but it worked perfectly. Thanks!
TheEther
Jan 14, 2017Guru
Netgear extenders will usually broadcast a new name consisting of the router's SSID with "_EXT" appended to it. If you want to change this, you will need to log into the extender.
