CW1971's avatar
CW1971
Connection
If I connect my extended to my wifi router by utilizing the WPS buttons on both the extender and router and they connect. Do I need to do anything else? In the instructions step 6 mentions connecting ...
  • CW1971's avatar
    Jan 15, 2017
    Got it. Had to go through my laptop but it worked perfectly. Thanks!
