mgist-007
Aug 24, 2018Aspirant
Connection
I changed to a new router. I cant get the unit to log on to either of my routers. I have a att u-verse modem but i an using the lynksys VELOP system. With the att wireless turned off and velop on ...
mgist-007
the wnce4004 is a netgear divice
schumaku
Aug 24, 2018Guru - Experienced User
Provide more insight.
Netgear WNCE4004 firmware version?
Changed network name and passphrase on the Velop along with the update?
Using any crazy characters for the network name (say things different from a..z, A..Z, 0..9) on either the provider router and/or on the Velop?
Using any crazy characters for the wireless passphrase (say things different from a..z, A..Z, 0..9) on either the provider router and/or on the Velop?
Any security settings on the provider router and/or the Velop potentially not allowing the association of the devices to the wireless network?
Wireless settings/config of the provider router and the Velop?
- mgist-007Aug 24, 2018Aspirant
firmware verison 1.0.0.32
the the network name and password are known and was changed. It seems to be loging on but it just says the signal is not stronge enough which i know it is. no my network name is moe. I have 20 items connected to the router now.
