Akis_P
Nov 25, 2015Aspirant
Connectivity problem WN2000RPT
Hello, i have just installed the range extender WN2000RPT and I'm facing a connectivity problem. I can have access in range extender only if i connect fisrtly in modem's wifi network. If i try to co...
- Mar 18, 2017
To all people with the same problem!!!
Here is the solution!!!
Enter repeater's adress http://www.mywifiext.net go to settings-wireless-ip adress and change "Get Dynamically IP Address From Router" to "Use static IP adress" click save and you can connect your devices to repeater without connecting firstly with your modem!
nhann
Nov 25, 2015NETGEAR Employee Retired
Hi Akis_P,
Can you please clarify your issue?
You first connect to the Modem Router's network, then you disconnect from the Modem Router and then are able connect to the WN2000RPT network?
Have you tried connecting to your WN2000RPT with other computers/devices?
Please download the user manual and follow the setup instructions:
http://support.netgear.com/product/WN2000RPTv1 (page 7 of 31)
http://support.netgear.com/product/WN2000RPTv2 (page 8 of 33)
- MausNov 26, 2015Aspirant
I have the same problem, but then on an wn3000rp. There are 2 problems. 1. when you connect you device first to the _ext network you will not get internet. You can solve this to first connect to the main network and then to the _ext.
The second problem that I have with the extender is that every, I don't know, 10 to 12 days I have to reset my extender because it wil not work anymore. I does have connection to my main and you can connect to it, but it will not give you internet ever. Not even with the description above.
I did a factory reset and set it up so that the extender is a extension of my main network. The ip adress is given by my main network.
I'm finding more and more information about this issue.
problem 2 looks very ... very similar to
- nhannNov 30, 2015NETGEAR Employee Retired
Hi Maus,
Thanks for writing in.
Can you please clarify which version WN3000RP you have? (v1, v2, v3)
http://support.netgear.com/product/WN3000RP
http://support.netgear.com/product/WN3000RPv2
http://support.netgear.com/product/WN3000RPv3
and also which firmware version that is currently on your WN3000RP?
- Akis_PDec 10, 2015Aspirant
Hello, i'm facing exactly that problem.
I have tried to connect other devices and every time and with any device have to do the same steps.
1. Connect on modem's network, to get access on wifi.
2. Connect on extender WN2000RPT after joining modem's network.
1st step cannot be skipped.
- nhannDec 10, 2015NETGEAR Employee Retired
Hi Akis_P,
Can you please clarify which modem you are using?
Which firmware version is on your WN2000RPT?
Have you tried changing the security modes on your Modem and Extender? (for example: temporarily try No Security (no password))
- Akis_PJan 06, 2016Aspirant
Hello,
Wish happy and healthy 2016!
Just changed the security mode removing the security code, but the problem remain the same, Modem is: WN2000RPTv3 and Firmware is: V1.0.1.4.
Please give me a solution, because it is getting more and more annoying doing this thing every day for one and a half month.
Thank you in advance.
