Akis_P
Nov 25, 2015Aspirant
Connectivity problem WN2000RPT
Hello, i have just installed the range extender WN2000RPT and I'm facing a connectivity problem. I can have access in range extender only if i connect fisrtly in modem's wifi network. If i try to co...
- Mar 18, 2017
To all people with the same problem!!!
Here is the solution!!!
Enter repeater's adress http://www.mywifiext.net go to settings-wireless-ip adress and change "Get Dynamically IP Address From Router" to "Use static IP adress" click save and you can connect your devices to repeater without connecting firstly with your modem!
Akis_P
Mar 18, 2017Aspirant
Hello,
I would like to be informed if you have find any solution on the existing problem.
Akis_P
