ecky
Aug 05, 2015Aspirant
Convert DG834Gv4 from router to repeater
I recently purchased a TP-Link Archer D7 which as I using as my main router and want to convert my old DG834 to an extender/repeater. I am having problems setting up the modems to comunicate with eac...
nhann
Aug 06, 2015NETGEAR Employee Retired
Hi ecky,
Please see documentation on DG834Gv4 for more information on Access Points. Page 30 of 168 summarizes some of the Wireless Access Point settings.
There is also a discussion similar to your question: https://community.netgear.com/t5/General-WiFi-Routers/Using-DG834G-as-a-second-router-access-point/td-p/365441
Let us know if these steps work for you.
NhanN
- eckyAug 08, 2015Aspirant
Hi nhann,
Unfortunately It's not the netgear 'extender' that's the problem. I have downloaded the info from your link but I can't find how to create the settings as shown in the document with my master wifi router TP-Link Archer D7.
If you could help it would be great.
Thanks
- nhannAug 14, 2015NETGEAR Employee Retired
Hi ecky,
If the issue is with the TP-Link, it may be best to contact their support for help on setting it up.
http://www.tp-link.us/support.html
Regards,NhanN
