Justkillamojo's avatar
Apr 02, 2020
device has no drivers installed
i have downloaded the support folders from netgear, all three versions in hopes that it will work. but when i go to search for drivers none of them work. i have restarted my computer and uninstalled the device three times. nothing seems to be working.
1 Reply
  • plemans's avatar
    what computer and operating system are you installing on?
    How are you doing the install?
    what error is it giving you?
    start by uninstalling all the drivers/software for the A7000.
    Make sure the wireless device is unplugged for setup.
    Then install the drivers.
    then reboot and plug in the wireless device
    https://www.netgear.com/support/product/a7000
