Maril's avatar
Maril
Device led is off
My device led light is off. Does anyone know how to fix it?
  • plemans's avatar
    For what device? You didn't put what you're using?
    you can go to netgear.com/support/ and type in your model number. It'll have a manual that describes what the issue is.
  • Thanks for the reply. I reset the settings but cannot connect. The device led was on but no internet. Any idea why?
    • plemans's avatar
      You factory reset the extender? Did you reinstall it? Did you do it using the wps method or using the installation wizard?
      What router are you connecting to?
      I'd recommend using the smart installation wizard.
      • Maril's avatar
        Maril
        I did the installation wizard. And factory reset. It used to work but the last week is not. Router Hub 3.0
