WretchedKing
Nov 13, 2018Aspirant
device light wont stay lit
My extender was working great til my kid unplugged it. Now I try and pair my router with extender and get no device green light. The one or two times I did get the extender device light to come on ...
Nov 13, 2018Guru - Experienced User
Maybe try doing a factory reset, and set it up from scratch. Instructions for that are in the user manual here: http://www.downloads.netgear.com/files/GDC/EX7000/EX7000_UM_EN.pdf
If setting it up with WPS fails, then try again without using WPS.
WretchedKing
Ok I'll give that a shot thx!
