Anach
May 05, 2015Guide
Device lockup (Orange light) on home WiFi
I've been trying to troubleshoot a problem I'm having with a secondhand EX6100. I bought the device from a friend that had been using it without problems, but when I reset it and connect it to my net...
tueselbert
May 26, 2015Aspirant
I have got the same problem! Have you solved it?
I have also disabled the guest network, it works fine until I reboot my router. Now the wifi extender brokes again.
Please tell me if you have a solution.
thank you!
thank you!
