Anach's avatar
Anach
Guide
May 05, 2015
Device lockup (Orange light) on home WiFi
I've been trying to troubleshoot a problem I'm having with a secondhand EX6100. I bought the device from a friend that had been using it without problems, but when I reset it and connect it to my network, the device locks up soon after and I have to power-cycle, even with no WiFi devices connected to it.
Initially I thought there were problems with the 5G, so I setup the device in 2G only, without luck. I've tried numerous settings, from leaving it basic config (wizard) to custom settings. I've reverted to stock firmware and then updated again. Nothing I seem to do makes a difference. I've lost count of the times I've reset this device.
The Ex6100 is connecting to a WNDR4500, both with latest firmware. I have zero problems with any other device connected to the WNDR4500, on either band.
I gave the EX6100 back to my friend to test again on his network and it worked fine for 2 days, where as I can only get a few hours at most, but usually around 5 minutes before lockup.
Thanks in advance for any suggestions.
  • I have found a solution. I noticed some of the other devices on my network (notably mobile phones), would need to have their wifi disabled/enabled to fix connection issues every now and then. So I started to suspect there might be something wrong with my router's wifi. I ended up installing DD-WRT custom firmware to my router (WNDR4500v1), and tried the Wifi Extender once again. It's been several days now, and I haven't had a single issue with any device on my network, not only that, but the connection is more reliable and faster; I have many more configuration options on the DD-WRT firmware, and at first it can be a little confusing to configure, but it's working flawlessly now. So it seems that there is a problem with the standard firmware of my router and wifi that causes other devices to drop-out or in the extender's case, lockup.
