Gmoney512's avatar
Dec 03, 2019
Devices not connecting to ax6000 extender
I have the ax8(ax6000) range extender.. the problem I'm having is once I get the device up and running..my devices will connect..then after a while the devices will not connect to it, even though the nighthawk app shows it's connected to my rax200.. when I power cycle the extender it comes back on the router light goes yellow and the connection rate via ethernet shows 5hgz band drops to 600mbps from 2.4gbps..then I have to factory reset
  • I meant to say the router led light on the extender is yellow after power cycling the extender
      • Gmoney512's avatar
        Gmoney512
        Tutor
        It's the latest..I figured it out..I had to lower the 5ghz bands to 2400mbps..now the extender stays connected...it would disconnect at the 4800mbps on the 5ghz bands
