gcolace's avatar
gcolace
DGN2000 + WG602v4 problem
Hi all.
I'm trying to realize an infrastructure with a DGN2000 modem - router and a WG602v4
in order to connect my TV to internet. The modem is connected to the ADSL and I'd like to use the WG602
in bridge or client configuration.
During the last days, I experiensed some problem. In fact, I'm able to access the WG602 and connect the DGN2000 as base station but the pc
connected to the WG602 can't access internet. the same result if I assign a static IP to the pc or if It connects the WG602 in DHCP.
In this case the connection is not realized.
DGN has IP configuration set on class 192.168.0.x;
WG has IP configurated as 127.168.0.227 and DHCP disabled.
Where is my mistake?
thanks in advance
  • Resetting unit WG602 I obtain same risultati.
    It looks likes WG602 is not able to assign anche IP totale devices who try to Connect via Cable or via wifi.
  • you are expecting to et 192.x IP on wifi device right?
    if you setups static IP does pass any traffic?
    Yes you're right
    No. If I set a static IP no traffic passes from WG to device.
    How can I test the WG is OK.
    I read something on the forum about to re-install firmware....
    What do you think about this.
    thanks in advance.
  • How can I get laster firmware and instruction for WG602v4?
    In the download support section there are only PDF.
    thanks
