ronnymac32
May 24, 2018Guide
Disable Beamforming on Nighthawk X4S Extender (EX-7500)
Hey everyone,
I did some tooling around on the Google box and found a lot of advice for adjusting settings on the Netgear Routers. Unfortunately, it seems more limited in the extender realm. Is the...
DarrenM
May 30, 2018Sr. NETGEAR Moderator
Beamforming should be a setting in the router the ex7500 does not have this option.
DarrenM
ronnymac32
May 30, 2018Guide
Thanks Darren. Do you happen to know if I disable beamforming on the router if the extender will follow suit? Or am I stuck with beamforming on the extender?
- DarrenMMay 31, 2018Sr. NETGEAR Moderator
yes that should be the case
DarrenM
