ronnymac32
May 24, 2018Guide
Disable Beamforming on Nighthawk X4S Extender (EX-7500)
Hey everyone,
I did some tooling around on the Google box and found a lot of advice for adjusting settings on the Netgear Routers. Unfortunately, it seems more limited in the extender realm. Is the...
ronnymac32
May 30, 2018Guide
Thanks Darren. Do you happen to know if I disable beamforming on the router if the extender will follow suit? Or am I stuck with beamforming on the extender?
DarrenM
May 31, 2018Sr. NETGEAR Moderator
yes that should be the case
DarrenM
