hohn67
Feb 01, 2014Aspirant
Disable redirection to mywifiext.net
Hi, I own a WN3000RP repeater, and I need to disable the setup wizard. Sometimes I have to reboot my main router for maintenance purpose and in this case users connected to the repeater are redir...
jmizoguchi
Feb 04, 2014Virtuoso
If that your personal take then that is your choice.
Using consumer level products are usually meant to be at consumer level to setup at ease. You need more configurable products then should look enterprise devices
