MPH832
Nov 25, 2018Follower
DNS problems with ATT UVERSE and EX 7000 extender
I got this extender because an ATT installation tech recommended that I get an extender for better WiFi coverage in a large home.
I have had issues with dropped connections before but more recently...
Nov 26, 2018Guru - Experienced User
If you suspect DNS, then you can set the DNS servers used in your router to use public DNS servers instead of using AT&T's.
Some options for public DNS are
IP address 1.1.1.1 (hosted by CloudFlare)
IP address 8.8.8.8 (hosted by Google)
IP address 8.8.4.4 (hosted by Google).
It's good to list two if the router lets you - perhaps Cloudflare and one of the Google ones.
- debonairilApr 19, 2019Aspirant
You can't change or add DNS servers to the AT&T Uverse router/modem. I have the same DNS issues.
