Logenergie
Jan 06, 2018Aspirant
Do More > Access Schedule Menu
Hello, Once connected, I see the menus at the top left. The firmware update is accessible. I am in V1.0.2.50. However, nothing happens if I click Settings or Do More. I would like to access the sy...
- Jan 17, 2018
After several tries, I understood that the problem comes from the touchpad of the Microsoft Type Cover keyboard for Surface Pro 3.
The Microsoft Surface Pro 3 allows access to the menus if you use the touch screen.
The touchpad on the Microsoft Type Cover for Surface Pro 3 keyboard does not provide access to the menus.
DarrenM
Jan 12, 2018Sr. NETGEAR Moderator
Did you try a different web browser or access the settings from a different device?
DarrenM
- LogenergieJan 16, 2018Aspirant
With a Microsoft Surface Pro 3, Windows 10 and Chrome, it does not work. Menus are not accessible.
With a Samsung S7 Edge, Android and Chrome, I can open the menus.- LogenergieJan 17, 2018Aspirant
