GPFisher's avatar
GPFisher
Documentation discrepancy - EX2700
In the User Manual for the EX2700 (http://www.downloads.netgear.com/files/GDC/EX2700/EX2700_UM_EN.pdf), it mentions that the operating temperature is 32f to 140f on page 43.  It also mentions that the operating temperature is 0c to 40c on the same page. The issue is that 140f does not equal 40c, but rather 60c.
Can anybody from Netgear please clarify this? I have purchased some units for use in environements that run about 130f.
  • Hi GPFisher,
    Yes, I have forwarded this to the right department and the documentation will be corrected. The correct information is 32f to 140f (0c to 60c).
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi GPFisher,
    Welcome to the community!
    Let me check on this.
    Dexter
    Community Team
    • GPFisher's avatar
      GPFisher
      DexterJB, have you heard anything about this yet? I noticed that the documentation still has conflicting information.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi GPFisher,
      Dexter
      Community Team
