VernonX
Dec 17, 2016Guide
Does Netgear EX7300 add value
My configuration is complex and has R8500 (1) with EX7300s (2) and EX7000s (3); it used to be EX7000s only (4). They all use the same 5Ghz SSID. One of the EX7000s (A) reports status connection speed...
VernonX
Dec 18, 2016Guide
Thanks, not a solution for my configuration.
I do not use wireless on the extenders (EX7000s). All devices at EX7000 location are connected to the ethernet ports (or USB port) on the EX7000.
I do not see a 50% drop in internet throughput as configured.
puttanaro
Dec 18, 2016Tutor
Hello, I wold like to know if Netgear EX7000 speed 2,4 gh up to 600mb is better than EX7300 speed 2,4 gh up to 450mb in longer distance!!!!!in some forums advise EX7300 for longer distance, but in theory EX7000!!!!sorry for my bad english!!!!
- VernonXDec 18, 2016Guide
I do not use 2.4 on the extenders. All of my connections use 5 (1733mbps on EX7300). I find that the R8500 2.4 distance is fantastic for my needs--'remote' 2.4 only audio media players.
I would assume the EX7000 would be best for you; plus you get the ethernet ports. I do not know why Netgear went with new design for the EX7300.
