VernonX
Dec 17, 2016Guide
Does Netgear EX7300 add value
My configuration is complex and has R8500 (1) with EX7300s (2) and EX7000s (3); it used to be EX7000s only (4). They all use the same 5Ghz SSID. One of the EX7000s (A) reports status connection speed...
VernonX
Dec 18, 2016Guide
CONFIGURATION UPDATE: Removed (BB) and used (B) instead. the increased speed [1733 versus 1300] for (BB) is not an advantage and using (B) eliminates the device reporting issue noted before. MU-MIMO not worth additional cost of EX7300 (BB) since I already have the EX7000 (B). Connection speed for (B) and (C) show as 1300mbps.
Getting up to 180mbps internet for computer connected to (C) ethernet port.
