twenty1670
Oct 14, 2016Aspirant
DST Adapter cannot connect to router with SSID broadcast turned off
I am trying to add a DST adapter to the Nighthawk AC1900 Router (Model R7300) but it keeps saying no DST adapters found. I have turned 'broadcast SSID' off on the router which I think could be the re...
twenty1670
Oct 17, 2016Aspirant
DarrenM, yes, tried that and didn't work. I think WPS requires SsID broadcast to be on to work
DarrenM
Oct 19, 2016Sr. NETGEAR Moderator
Hello twenty1670
Are you not able to enable the SSID connect the extender then disable it again?
DarrenM
