gig1029
Jun 28, 2016Follower
Dual band Access Point suggestions
Hello I am new to the community, have looked through some of the discussions but have not found anything to help with my issues. my apartment is large 7 rooms in approx 2000 square feet. with a...
DarrenM
Jul 05, 2016Sr. NETGEAR Moderator
Hello gig1029
Most of our extender have a ethernet connection that you can connect your bridge to and program them as APs you can also use any of our nighthawk routers to do this as well they can be used as APs. In AP mode you will be able to use the same SSID.
DarrenM
