kasaattila
Mar 05, 2016Aspirant
EAP-MSCHAP v2 - Netgear WN3100RP
Dear Community, I need to know is it possible somehow to set up a known network with the known USERNAME and known Password on the Netgear WN3100RP? I would boost up the located WiFree signal, bu...
- Mar 13, 2016Thanks for your help a lot!
TheEther
Mar 05, 2016Guru
Looks like you need an extender that supports WPA2 Enterprise. According to the data sheet (link), the WN3100RP only supports WPA2-PSK. I don't think any of Netgear's extenders support WPA2 Enterprise.
You may have to use a router that supports DD-WRT (3rd party firmware) to do what you want. I found a thread on dd-wrt.com that talks about how to set it up (link).
