pubpurc's avatar
pubpurc
EAX20 AX1800 how can I change the security type
When my iPhone 12 Pro is connected to the extender, the phone tells me that the connection has a weak security. I tried to find out the security type ie. WPA, WPA2 or WPA3 on the extender. The Wireless section of the extender GUI shows only that the connection is protected but it does not tell me which security type it is using. How can I change the security type for the bands?
    • pubpurc's avatar
      pubpurc
      Thanks for the suggestion. In fact the security type can be set manually when I create a new password for the bands instead of using the same passwords as the router.
  • I found that with my current Netgear Router (R6700AX) set with WPA3, WPS will not connect, even when I use a direct Ethernet connection.  The Router does not see it.  When I demote Router to "No Security" and WPS, the extender is seen and I can log in to the extender setup.   I left the Ethernet connected during the initial setup.
    (BTW, the login that worked for me:  http://mywifiext.local/start.htm
    User Login (mywifiext.local)
    After logging in to the extender, I just used the SMART Setup and made sure I answered the One Name, etc.  Same PW, etc.
    When all done, your status may show that the 2.4 GHz not enabled/connected.  Don't worry.  If you say "Yes" to all the available options, your extender will broadcast and decided the best avenue/connection wherever you put the extender.
    In my house the router is on one side and the extender gave me over 100 megabits/s, 40' away - doubling what I had.  Not gaming speed, but happy for streaming videos and I didn't have to relocate the router.
    Happy.
