TeamTricky's avatar
Mar 01, 2023
EAX20 AX1800 web page "Settings +" button does not expand to show sub menu items
Just purchased the EAX20 AX1800.
It seems to be working just fine, and I am happy with it.
When I login into the web page from one PC, the "Settings +" and the "Do More +" buttons do NOT work.  These should expand into a list of sub menu items.  Since it does not expand, I can not get to these settings.
When I login from a different PC, the buttons work properly.
Both PCs are using Windows 10, both are using Chrome.  They are similar but different.  What setting on my PC (or in Chrome) would cause this?
  • plemans's avatar
    Mar 01, 2023
    No clue why its working on one device and not the other.
    You can try clearing cache/cookies and see if that helps
  • plemans's avatar
    Try a different web browser on that pc.
    • TeamTricky's avatar
      TeamTricky
      Tutor
      Good idea.
      I tried Microsoft Edge, and it worked.  This is the first time I ever launched Edge on my PC.  I always use Chrome.
      So any ideas as to what would cause this to work with Chrome on one PC, but not another?
      Both PCs are using the same Chrome Version 110.0.5481.178 (Official Build) (64-bit)
      • plemans's avatar
