Kman1
May 24, 2022Aspirant
EAX20 Extender is setup. Downloaded app and it wants to repeat setup?
Latest firmware on my EAX20 Extender. Using as an access point. All setup using Ethernet, then that quit, and I was able to use my iPhone to finish. Had to enter SSID's twice, once on my laptop, which then disconnected, and again on my iPhone. Got it setup with latest firmware, so I wanted to download the Nighthawk app, to monitor. App wants to run setup again. Plus when I tried to login to Netgear, said user name wasn't valid. Same credentials I used to login in here. Is there anyway to use the app after setup has been completed? Because that is where it was heading. It would make the 3rd time I would have to setup. Any ideas? Thank you.
The app should autodetect that its already setup and you're connected. I'm surprised it didn't.
I've actually used that method before to test out my EX8000.
If it was me? I just wouldn't use the app. But its not really a fix.
You can try the factory reset and reinstall through the app if you'd like.
- Kman1AspirantThank you for the reply. I deleted app and downloaded again. This time I got logged in, and to the point of app connecting to extender. But it will not connect. I’m standing 3 feet away, and on the extender Wi-Fi with my phone. On the 5g, and guest network is off. Logged in using Safari, and It says all is well, and access point is functioning. I’m with you, I won’t use the app. This method gives me access to what I need. Thank you again!
If you're on ios, make sure icloud relay is disabled. Same with random mac/ip address. They can cause issues on the app
