pbear74
Aug 13, 2024Aspirant
EAX20 extender issues
I have a Nighthawk RAX80 router and a AX1800 Mesh Extender EAX20 extender, it is connected however i am noticing that it will randomly lose connection to either the 2.4 ghz or the 5 ghz signal fro...
Aug 13, 2024Guru - Experienced User
No. If its hardwired router--->extender, you'd need to set it up in access point mode and not extender mode.
What router is it connected to?
Did you set it u using wps, the installation assistant, or the app?
I usually recommend the installation assistant.
