pbear74
Aug 13, 2024Aspirant
EAX20 extender issues
I have a Nighthawk RAX80 router and a AX1800 Mesh Extender EAX20 extender, it is connected however i am noticing that it will randomly lose connection to either the 2.4 ghz or the 5 ghz signal fro...
Aug 13, 2024Guru - Experienced User
No. If its hardwired router--->extender, you'd need to set it up in access point mode and not extender mode.
What router is it connected to?
Did you set it u using wps, the installation assistant, or the app?
I usually recommend the installation assistant.
pbear74
It is connected to a nighthawk rax80. I do not want it as an AP because i do not want two separate networks.when i installed the extender i go through the web interface.
- plemansAug 14, 2024Guru - Experienced User
How big is the home?
How far from the router is the extender?
Are you using dfs channels on the RAX80? Might be worth setting the speed down to "up to 2400mbps" to limit usage of DFS channels.
what are you interior walls made from? (certain materials block wifi better than others)
- pbear74Aug 17, 2024Aspirant
My house is about 2600 sq ft, the router is upstairs and the extender is downstairs. They are about 25 feet apart with no direct line of sight. The walls are standard sheet rock. Not sure about dfs , where is that set?
- plemansAug 19, 2024Guru - Experienced User
DFS is a specific set of channels that devices are forced to move off of if an approved device is broadcasting on it. If your router is set to "up to 4800mbps" speed, its using dfs. Set it down to up to 2400 and change to either the lowest or highest 5ghz channel.
