Jim-1021's avatar
Jim-1021
EAX20 extender will not connect
My EAX20-100NAS  AX1800 connects but has no internet. Tried for 5 hours
  • plemans's avatar
    What router are you connecting to?
    Are you setting up via wps or the installation wizard?
    I'd recommend the install wizard and not wps.
    What firmware is on the extender?
    How have you tried installing and what steps have you tried? "tried for 5 hours" doesn't tell us much.
    • Jim-1021's avatar
      Jim-1021
      I have the Spectrum router Askey  RACZU1K,  I also have been online with a netgear support for over an hour. We reset the extender typed in the ip in the web address to enter setup. Went through every step and it finally showed up in the selections to choose from. But still says connected not internet secured. The netgear rep got fed up and said send it back.
    • hmcdaniel11's avatar
      hmcdaniel11
      AX1800 will not connect "Unable to find router". Attempting to Connect to Comcast XFSETUP-7478
      • plemans's avatar
        please start your own thread instead of jumping on someone elses. Then we'll be happy to help.
