krawczyn
Jun 16, 2021Aspirant
EAX20 Speed limited to 100 Mbps
I have had the eax20 setup and working for about 2 months now in access point mode where it is connected to my primary router via ethernet. Randomly today it stopped working and I have run into some ...
Jun 17, 2021Guru - Experienced User
Try moving the extender to next to the router and grabbing a 6ft cable that is cat 6 or better.
then test the speeds.
It wouldn't be the first time a sketchy cable or cable end has caused a device to drop to 10/100mbps link speed and not gigabit.
- krawczynJun 22, 2021AspirantI think I'm confused how it could be the ethernet cable since if I remove the ethernet cable from the extender and instead plug it into my computer and run a speed test I get the expected result. The extender itself is definitely causing the issue somehow.
- plemansJun 23, 2021Guru - Experienced User
Some devices are more sensitive to sketchy cables. It can potentially work on some devices but not others.
thats why I recommend using a high quality cat 5e or greater cable and just a 6ft one. Its to ensure you're getting a gigabit connection.
If that works, then you start looking at the cable you've ran to where the extender is located.
