AMCooper63
Nov 06, 2022Tutor
EAX80 Nighthawk AX8 Reset and Cannot Connect
I needed to reset my EAX80 Nighthawk AX8. I pressed the reset button for 7 seconds and after I let go, the router rebooted. By the fact that my SSIDs were no longer transmitting and a new SSID NETGEA...
Nov 08, 2022Guru - Experienced User
use the mywifiext . net
(can't put the whole thing in there)
AMCooper63
Nov 08, 2022Tutor
Thanks for all your help. I gave up and put the thing in the recycle bin. New one should be arriving today.
- AMCooper63Nov 09, 2022Tutor
Just to close the loop, my new Nighthawk RAX200 just arrived and it worked as expected. Something must have died in the old router. I use the routers in AP mode and for a long time I could not access the setup pages in the old router once it was placed in AP mode. This new Nighthawk RAX200 still works fine in AP mode and I can still access the setup pages.
Thanks for everyone's attempt at helping out.
- MSFFAMMar 23, 2023Tutor
I had the same experience with the AX8.
I wanted to reset it, and after resetting it, i was unable to reach the web ui to reconfigure the router.
I tried using telnet to see if I can reach port 80/443 on the AX8 after the reset, and I was unable to connect to the HTTP/HTTPS ports on the AX8.
In the end , i came to believe that i will not be able to use the AX8 anymore since the AX8 web server is not running, thus, i am unable to connect to re-configure the router.
I also have an RAX80 and RAX120 devices, so i am familiar with netgear/nighthawk products.
I was surprised to realize that the web server was not starting up after the AX8 reset.. i do not know why.
