Reefs
Oct 20, 2023Tutor
EAX80 Performance issues
I’m seeing performance of this extender slowly degrade over a period of a month or so. Are there any known issues? After a factory reset, the extender works well. It has a few issues from time to t...
Oct 21, 2023Guru - Experienced User
what router are you connecting it to?
Have you tested speeds over both 2.4ghz and 5ghz to see which is causing the drop?
also, make sure if you're speedtesting for peak speed to be attached to 5ghz as its a much faster network
How far from the router is the extender?
did you try changing wifi channels when speeds slow?
Reefs
Oct 21, 2023Tutor
It’s a Virgin Media Hub 4
I’ve spent a lot of time trying different channels and WiFi configurations.
I’ve found the 2.4Ghz band drops packets - which appears to be on the Hub 4 side.
5Ghz is stable, and doesn’t drop packets. I get full performance speed. I have wireless and wired from the extender, so it isn’t a WiFi issue from the client.
When it degrades everything is affected.
It would be good if there was any logging that could be viewed. I feel like it will be something less visible like an internal log being full, etc….
- plemansOct 21, 2023Guru - Experienced User
You put 5ghz doesn't drop but then later said everything drops/slows.
Just wanting to clarify if everything does or just the 2.4ghz.
And wired devices connected to the EAX slow down as well?
That tends to indicate an issues between router---extender
And whats between them (walls, thickness, how many, what are they made of)
when it slows, get a screensnip of the status page on the extender, that'll show that backhaul link
- ReefsOct 22, 2023Tutor2.4Ghz drops packets consistently. So I’ve set the extender to only use the 5Ghz band to the router.
The 5Ghz band works perfectly for many weeks then degrades. It goes from full speed which in my case is 270mb/s down and 25mb/s up to 0.5mb/s down and 3mb/s up
Wired connections in to the extender degrade too.
There is about 4 - 5 metres between the router and the extender. Router is on the ground floor, extender is on the first. In terms of materials, there will be timber, plasterboard, carpet. Nothing too heavy.
I’ve factory reset the router again recently to resolve the issue, which encouraged me to use this forum. Performance has been back to normal now for a few days. I’ll keep an eye on it and post back when the issues start again.
For info - the status page shows a strong and healthy connection, but I’ll screenshot too
