Bwyman
Dec 26, 2017Follower
Email for mywifiext?
When I try to access mywifiext to use the setup wizard the login screen requires an email and password. When I enter in my email it tells me that the password does not match. I have tried resetting my password and still nothing.
I have also tried resetting the device to the factory settings and using admin/password to login and it tells me that it is not a valid address.
I'm running out of ideas. Has anyone else run into this problem?
1 Reply
- DarrenMSr. NETGEAR Moderator
Try to factory reset again and make sure you are holding the reset button for 10+ seconds.
DarrenM
