rcooke1963
Sep 02, 2018Aspirant
Error Trying to update firmware on a WN2000RPT
Current Firmware info:
Hardware Version | WN2000RPT |
Firmware Version | V1.0.0.24IC |
GUI Language Version | V1.0.0.10 |
On the firmware tab, I click "Check for update" (server is ftp://updates1.netgear.com/wn2000rpt/ic) and after a few seconds I get this error:
"Firmware could not be downloaded, check internet connection".
But I clearly have a connection since I'm connected to the Extender and I'm on this web page!
My current firmware version matches V3 hardware so I downloaded the latest file. But when I try to load it, I get this error:
Error upgrade file module name! (Module name is "WN2000RPT")
Just for "fun" I tried to load each of the V2 and V1 firmwares and also got errors.
Is there a work around or fix for this?
Thanks in advance.
Following... :)
Did you extract the img file from the zip (and then install the img file)?
The current firmware for the WN2000RPTv3 is here: http://www.downloads.netgear.com/files/GDC/WN2000RPTV3/WN2000RPTv3-V1.0.1.32.zip
- rcooke1963Aspirant
This is my second attempt at replying! My first attempt never appeared, even though I got a "reply" badge for it.
Thank you for the input.
I did, indeed dowdnload the .32 latest ZIP file, unzip it, and then try to upload the IMG file. I even connected to the AP with a wire!
The automatic update does not work either, and I just tried to access the FTP address it is using. There are no files on the server! Has the FTP address changed?
